2G starter relay surges
inthemidst
363
24
Aug 25, 2009
PALMDALE, California
I have a 96 eclipse gst m/t. installed remote start and replaced original starter relay with aftermarket relay.The type that has 85 86 87 87a 30 numbers on them.Im sure i wired everything properly because its been working fine for a while.anyway when i remote start it cranks up fine.when i go use the key it cranks but with surges like its cranking for a sec then nothing and then cranking so i get a little grinding at the starter i also hear a buzzing sound from relay when i use key.if i remove the ecu fuse the car cranks perfect with remote and key.Any ideas help is appreciated.Thanks
