Resolved 1G - Need OEM or Substitute part for a 1g Crank ANGLE Sensor (Trigger sensor?) 7 Bolt Engine
Chad Noles
7
Mar 15, 2022
Linville, North Carolina
I need a replacement for a 1g 7Bolt Crank Angle Sensor. Is it also called a trigger sensor?
Not sure, but I'm talking about the part that is just above the Crank sprocket and the oil pump on the front where the timing belt runs. I can't seem to find any that are available for that year (1993).
I know people use those Kiggly 1g 6bolt on 2g cars but I need ANYTHING that will work on a 1g 7 bolt 2 tooth plate. I have the Cam Position Sensor but not the Crank Angle Sensor.
Any help would be greatly appreciated.
As far as I remember all 1g's (6 or 7 bolt) use the CAS for both Cam and TDC sensors. The 2g's have a crank angle sensor using the toothed plate and sensor and then either a cam angle sensor on the intake cam sprocket (95 & 96) or on the rear of the intake cam (97-99).
I guess I got confused watching too many videos of 2g timing belt replacements.In my mind I thought there had to be one of those magnetic sensors that pick up spark timing from the crank plate.My bad,but thanks for the help.
