1G 1g bad cas = no fuel pump signal ?
Marceldsm
321
3
Jan 13, 2010
Montreal, QC, Canada
hello to all dsm tuners alike
I have multiple problems from a fuel tank leak to a no start.
My car right now doesn't start because of low fuel pressure. When I opened the fuel line from under the tank there is no fuel coming from the fuel pump, can the CAS effect the fuel pump circuit?
Sorry for my bad English , please no insults I'm French Canadian so please dudes let me know.
tank you
Well the CAS on a 1g does the crank and cam signals. So I'd think that it would cause a no fuel pump issue.
Get a Haynes manual and check to make sure your CAS is getting power with the key in the "ON" position. Check your fusible links first though (the three or four big fuse lookin' things on the battery terminal). That will narrow your options down pretty well.
