1G 1993 1GB GSX ABS REMOVAL
James_24
5+ Year Contributor
40
17
Sep 25, 2018
Puyallup, Washington
I have a 93 1GB GSX and i am in the process of removing the abs lines and associated equipment and I've searched and have not found this particular item and it is not in the diagram for the break system as well. My question is does anybody know what this is?
Here is the diagram i have as well and its not listed.
Any help is greatly appreciated.
Thanks I'm sure this has been beaten to death but i need to actually make a post this is my first thread so thanks for any future information.
Is that the right diagram for your car? I have a 2g so I can't help to much. But it's a very detailed diagram to show body mounts/clamps for your brake lines but then doesn't show the brake reservoir is why I ask.
From the 1GB FSM:
ABS
Non ABS
From the 1GA FSM (1GB the same) Clutch lines.
Which are you trying to highlite?
The DSM wisemen have spoken! Holy smokes seriously thanks a ton. I was going about the removal of lines and stopped because i didn't know what this system was for.... I should have been able to figure this out on my own but hind sight is 2020 right?
Seriously thank you for the replies I appreciate the information greatly.
No i am removing anything to do with abs, then replacing with non abs hard lines.. I should have known that they were two different systems.
While we are here could i ask another question about getting rid of the abs system?
Basically is there any other hard ware associated with this system that needs removed?
