- Ownership Status
- Currently Own
- Year
- 1993
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Currently as for "bolt on's" inatalled on the car i have a sweet mishimoto weighted shift knob inatalled on the shifter.
- Mods-Engine
- Stock rebuild with stock parts
Uodated lifters
Line honed
Decked
Standard bore
New valves oem
Lapped valves
Oem mitsu standard bore piston
New rings
Oem lifters
Stock cams
Meling oil pump
- Mods-EMS & Logging
- esm link v3
Still need to complete speed density parts purchasing
- Mods-Drivetrain
- 4 bolt rear end?
- Mods-Handling
- years old(Have to go look at it)
Some bushings for rhe rear end
Bigger breaks
- Parts Wishlist
- all of them
[ ] Fuel system
Parts i need
• Fuel Filter
• Re wire fuel pump
• Adjustable Fpr with gauge
• New fuel line from filter in bay
[ ] Forced Induction
• FP red turbo
[ ] IGNITION SYSTEM
• Spark plugs (BPR7ES)
• Ngk wires
[ ] Engine Management
• Speed density set up MAF, IAT, BUNG
[ ] Instrumentation
• AFR wide band
• Boost gauge
• Oil pressure gauge
• Water temp gauge
• EGT GAUGE
• GAUGE A PILLER
[ ] BALANCE SHAFT delete
• Md103722
• Md092785
• Md098626
• Oem timing belt (MD326059)
• OEM TENSIONER
[ ] Misc
• Rear hatch struts
• Rear hatch open cable
• 1G non cruise control throttle cable
• Injectors harness clip
- Background
- Basically, without writing a novel this car was barted to my bro in law for an engine swap he did back in 2013. He swapped a GSR into a hatch and got ir running and driving great. Mind you this man got me into working on my own cars and modding at the age of 17. Later he did the swap and got the gsx as compensation.
Here is the downfall of thia gsx.
It is a manual boost controller....
My man turned up thw boost amd floated a valve..
He sold it to his brother.
My brother in law then later died in a car accident.... R.I.P Missa
His brother a (heavy equipment mechanic), rebuilt the engine with stock rebuild parts.
Then had to sell the unfinished product because of lack of storage.
I then picked it up from my brother in laws , brother for a good deal.
I now have this DSM and I like to say this car chose me as i did not choose it.
Therefore this is the story of my Eclipse in a nut shell. I want to wish everyone safe track runs, safe drive homes from work but at the same time I'd like to say stay dangerous. Life is to dam short to be a boring mother fuc**r. Push yourself to the limits and don't hold back. Get some while you can and remember life is suffering. No one is perfect but i want my dsm to be.......
Insert laughter here because its A DsM hahahaha. Well that's all folks thanms for readomg if you did.
- Dyno Shop Name
- One day
- Dyno Session Details
- Nothing still
