1G 1991 GSX boost issue
Db_datsun
4
Jan 25, 2026
Lake Forest, California
Hey everyone,
I recently picked up a 91 GSX and for some reason the car loves to go to 14 psi+ and hits a fuel cut at 5krpm, if I feather the throttle at 10psi it pulls and reves out as normal, I checked the vacuum lines,
turbo inlet pipe nipple ------ wastegate
I
I
BCS
I
I
AIRBOX NIPPLE
PCV valve is correct as well, so im a little stumped, the only thing modded is the 2.5in exhaust
Bad spark plugs & wires are often a culprit that people identify as fuel cut. It's not fuel cut. It's a spark issue.
A boost leak can be another.
Could be other things as well if you provided more information. A vehicle profile goes a long way to help us out.
Bone stock other than a 2.5in exhaust.
If it wasn't violent, it wasn't fuel cut. Misfire is more likely. Look closely at the spark plug boots. Small white dots are where a spark jumped through. Electrical tape may buy you a few days if you find this. If you dont know age of plugs and wires a new set is in order.
I'll start there, additionally is the bcs properly setup? Also is the stock boost 14psi i was seeing different places say different things.
No. It isn't 14psi. Its 11psi on a 1g.
Concerning the boost solenoid you should have a line out of the turbo outlet to a T. One side of the T goes to wastegate actuator, other side goes to boost solenoid. The outlet of the solenoid goes back to the intake pipe before the turbo. The solenoid is just a factory bleed off. Many solenoid were modified also and those cars did achieve approx 14psi. It was so easy to do many of us did it because it take like 5 min to modify the solenoid.
Is there a cat on the car? Chances are, if there is a 2.5 inch exhaust system on a 1g, the cat may have been replaced by a "test pipe".
When that is the case, then look what happens. The red curve here was this otherwise nearly stock 1992 GSX but with an aftermarket downpipe and no cat.
Where the red curve ends at 5,000 rpm, that was fuel cut.
They said boost was 17 psi at that point.
Sounds a lot like what you are describing.
The blue curve was a previous run with the car nearly stock, for comparison.
These engines are extremely responsive to exhaust system upgrades.
Awesome thats good to know! Im pretty sure the BCS is set right then, i just bought a boost leak tester so im going to try that today and go from there, so far the pcv valve and BCS checks out, seems to have a slight missfore as well I can barley feel it, so im swapping the plugs and checking the timing today as well
The previous owner said he purchased an aftermarket cat to pass smog so, I'll verify that claim LOL
Take a look at the downpipe too - see if you can verify whether it is stock or an upgrade. The pipe that goes from the O2 housing to the cat (or to the test pipe).
Sometimes people put a resonator in place of where the cat or test pipe would be. A resonator is larger OD than the pipe, so sometimes just looking at it from the outside, you might not know for sure if it's a cat or a resonator. But a resonator is open straight-through inside, so restriction to exhaust flow is pretty much zero, like a test pipe.
I posted a new thread because this issue has completely become something else
I would love if you could take a look at this thread as this issue has become something else entirely
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
