- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- HX35
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Homemade short runner intake, Punishment FMIC, Shearer twin scroll top mount, billet wheel Hx35-12cm² housing, twin 44mm gates out the hood, full 3" exhaust w/ straight through muffler (currently open dump under the pan), FIC 1150s, Aeromotive a1000, Walbro 255 rewired, battery in trunk
- Mods-Engine
- 91-6 bolt, Delta-Kelford 272s, BC springs/retainers, no balance shafts,
- Mods-EMS & Logging
- Ecmlink v3 on SD, lc2, autometer water temp - oil pressure - boost,
- Mods-Drivetrain
- South Bend SS-X/B, Act streetlight, stock lsd rear
- Mods-Handling
- Full poly suspension bushings, poly motor mounts, solid subframe bushings, solid rear diff mounts, 275s on 17x9s
