16g turbo water water lines after 6 bolt swap???
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
So this is the new problem. i have a 6 bolt swap on my 2g but there are NO water lines for my turbo :confused: so as of right now i have them T'ed into the same water pipe=bad idea i have a 16g turbo what do i do because that is were my coolant leak is do i take out the coolant lines and run just oil or were do i put the water lines ??
why dont you have water lines?
If you run a 2g water pipe and water neck than you will only have one supply. On a 2g 7 bolt block the turbo get's it's water from a banjo fitting on the front of the block. On a 6 bolt it gets it from the thermostat housing. Pretty much the only way around it is to t off the thermostat housing, or drill a hole and install a new nipple on the housing.
Read that thread. I didn't provide it for my health.[/
I did, a water cooled turbo needs water. what do you use ?
Ok if i go no coolant to the turbo do i leave the lines open or do i cap them off some how ? thinking of no coolant to this small 16g since gofer did for over a year.
Do i leave the lines open or do i cap them off ? for the coolant lines ??
