1g 16g water lines
chasedardis
133
Mar 7, 2010
novelty, Ohio
I just bought 6 bolt long block fully assembled for a 6 bolt swap. Their are no water lines on it I know I have to get the right banjo bolts and fitting I just don't know where to hook up the feed and drain tubes. Any help would be nice
did you get the coolant pipe that goes to the water punp? it has a line thats already welded in and you need it for the turbo. the other coolant line comes out of the tstat housing on my, my oil in line is stock out of the head.
