16g water lines
red21t
31
Jul 5, 2008
Mankato, Minnesota
so i have a 99 gst..... bought a new t25 for it, ran to much boost, turbo took a shit. sent it back to where i got it, guy sent me a small 16g under waranty no extra charge...... sweet effin deal right? well i recieve the 16g to find out i didnt take my water lines off my t25, i listen to vfaq and get water lines for a 94gsx.... the return line has a bolt on the line and the end bells out on the line instead of being able to slide the hose on the line evidently i have to screw the return line into someting?????????? and just to let you know if you order water lines from mitsubishi you have to order the banjo bolts also :banghead:??!?!?! wtf is that shit, i got my water lines with no banjo bolts so now i have to order those cus no place in the world carries them......... so what do i do about the water return line that has a bolt on it and bells out??? and do i have to bend the lines to make them fit with the 16g?
you could slide the hose in
or cut the bell, take the bolt out and then slide the hose in
u wont need to bend the water lines since they are made for the 14B
it has the same compressor housing as the 16G
