16g Internal watsegate arm question. Snap Ring?
Alpha
34
Jan 27, 2013
St. Augustine, Florida
I am having trouble figuring out how to connect the wastegate linkage arm to the actuator. I have the Actuator sitting on the arm, i just can't lock it in with a pin. The arm is different than others it seems, there is no hole to slide a pin through, just a indentation going all the way around. looks like a snap ring could fit in there.
If that is what is supposed to fit in there, anyone know the size? If not, thinking about busting out the JB weld.
Its an ebay 16g turbine housing. It will take a small c-clip to hold the WG rod in place. I would try to souce a clip and stay away from the JB weld. It wont hold...
Beatin to it by seconds. ^^ :)
I got mine hooked up just using the c clip..If your gonna use a 14b actuator, or non ebay actuator, you will need to drill out the hole on the end of the arm.Then use the c clip to secure it to the wg flapper.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
