[email protected], T25, very little mods
Not really due to so little mods done to the car...but it did do something
Only cause I didn't have anything to cover the hole on the intake pipe
Having it recirculated like that is not a bad thing....In theory, it can help reduce lag in between shifts, but I doubt you would have to worry about lag with your turbo.
Either way it is extremely impressive to see these times out of a T-25 car man. Keep us updated!
Great read, just constantly seeing little things done and little improvements made. Keep up the good work, I like seeing people use what they have instead of slapping on a dozen of the baller parts.
...just a check in, see what you have planned this season..!
ive got the t25 itch, and opening day is 5 days! Im reaalllyyyy wanting to just break 13s,but i think i have a little bit more to do...
I honestly don't see a FWD breaking into the 13's with a T25 too easily....especially on an otherwise stock setup. The 60ft times are going to kill you.
I'd set the bar to have the highest MPH in your class- perhaps the fastest T25 FWD trap speed in a stock platform....that shows you can really drive and you know your car very, very well.
Right now I need to rebuild the trans, just waiting on the 4 spider center diff from Jacks Transmissions. Third gear started to grind so I decide to do the 4 spider diff and some EvoIII gears with double synchros.
I think I'm just gonna do a 1G non-turbo 60mm throttle body next, go to the track a couple more times and try to get as close to 13.0 as possible.
We'll see what happens.
Well good luck man. I have enjoyed following your progress.
Went to an event today and ran a new personal best of [email protected] with a 1.723 sixty foot.
Since the last post, I rebuilt the trans with Evo III 3rd & 4th double synchros and a 4 spider center diff.
I also started preloading the car using the e-brake which helped get low 1.7 sixty foots all day and awesome .022, .040, and ,.071 reaction times
<a href="http://s34.photobucket.com/albums/d140/TurboDaveGST/?action=view&amp;current=Picture-1.jpg" target="_blank"><img src="http://i34.photobucket.com/albums/d140/TurboDaveGST/Picture-1.jpg" border="0" alt="Photobucket"></a>
I hate to bump such an old thread, but this has become my goal to match your times. I just ran a 13.54@100mph with a 1.845 sixty foot on E85 (stock clutch) tonight and I was very happy. Trying to get ahold of an upgraded wastegate to hold more boost! :)
Awesome! I'm also currently in the process of taking my BigT25 to the limit. Waiting on SD, FP race mani, slicks, and shock/springs. You're officially 3rd on the ladder (no nos), if you post your time. I'm FWD however so maybe I can get the fastest fwd t25 :D
Best of luck with it, let us know how it progresses!
I'm currently running a 14b but if I ever rebuild one of my 25s ill run it again. Idk about 1/4 mile I dont have one close but my best with the T25 fwd was a 9.9©69mph with 2.241 '60. Think that was like the fourth time I've ever dragged. I've done only around 15 passes ever LOL.
Last time I ran on 14b I slipped the clutch and it didn't stop slipping till I shifted to third.
Anyone know the top 5 t25 ETs no nos?
Edit ^ 1/8th mile time. idk how to judge 1/4 by the 8th.
1.84 - 1.72 = .12
13.54 - .12 = 13.42, so you're definitely set to go faster than the 13.37 with a better launch as you've already posted a better trap speed.
Post the time to where? And what's a BigT25? Hopefully I can get back out to the strip once or twice this year.
1.84 - 1.72 = .12
Ya, definitely room for improvement in the launch. I'm getting consistent 1.8-1.9 sixty foots, just need to keep practicing. I don't think the stock clutch is helping matters either. The only think that changed since last time I was at the track was swapping to E85 and retuning. I picked up a full second just from that alone. I'm officially in love with E85 :hellyeah:
By the way, that Holset actuator we have laying around is an aftermarket Banks 43psi unit. Guess I won't be putting that on after all LOL
Are you still using the clutch accumulator on your car? Anthony saw a huge improvement in his T25 time after deleting the accumulator....guess he was losing a lot at the start as well as between shifts.
Wanna trade? :sneaky:
Perhaps I'll take you up on that offer if I can't find an FP one. I'll have my people call your people.
A few people were saying that he needs to work on his launch for his 60 foot time. It's at around a 1.8. Isn't that good? I can't seem to get mine below 2 seconds.. :cry:
1.8 is a decent 60ft.
1.7 is pretty fast for someone that doesn't spend a lot of time at the track.
1.6 is about all you're going to get on street tires, even for a seasoned racer.
1.5 and faster is what a normal manual drag car with slicks should be seeing.
1.4 is considered pretty nasty, even for a drag car. You're going to be breaking axles and things pretty regularly if you're making a bunch of power while running slicks and cutting 1.4 60's.
1.3 is just plain ridiculous.
1.2 is too fast to comprehend.
I see :hmm:
So my 2.2 60' time is garbage :cry:
I need some practice if I'm going to try and go for a good time. My goal by the end of this year is going to be a 1.8 for my 60'.
