99eclipsegs-2t
- 77
- 116
- Jan 22, 2024
olympia,
Washington
This one?
Yep! Never saw this for some reasonThis one?
got one on the way!
I don't think that's my issue. I can't even get my car to enter program mode to even sync the remote.It's interesting to me that I bought one recently and you did as well and neither of us can get them to work. Wonder if a bad batch got produced.
Am I missing the module to program a fob?
Ok so I got one from a 98 Talon but mine is a 95. I didn’t give programming a try yetIf that’s the drivers side then you’re missing a few pieces
1. Locate the Data Port.
2. Insert keys in ignition and leave in the OFF position.
3. Make sure there are metal contact pins in terminals 1 and 4 and connect the Data Port with a suitable jumper wire, leave jumper wire connected throughout the programming procedure. Make sure you know which terminals are 1 and 4.
4. Within 10 seconds after connecting the jumper wire, turn the ignition switch to the ACC position and then back to OFF. Note: The doors will automatically lock and unlock once at this time indicating that the system is in the programming mode.
5. Press the LOCK button on the transmitter to be registered three times within 10 seconds. Upon successful programming, the door will lock and unlock once.
6. If there are two remotes, register the first, then register the second. Repeat step 5 within one minute to program second remote. After completing the second programming, the doors will lock and unlock once.
7. Disconnect the programming wire and remove the keys from the ignition
Very early production 95 model cars had a switch on the keyless module to put the car in programming mode. You would need to removed the drivers rear trim to expose the module to see if there is a switch on itNo matter what I do, I can’t get it into programming mode. Everything else works perfectly.
I know this is an older thread but has anyone got one of these remotes to program lately? I see the last couple people to post weren't able to and I'm having no luck either. 97 gsx bone stock and my door locks work, doors closed, hood closed, trunk closed. Im able to get it into programming mode (jumper pins, key to acc then off and my doors lock and then unlock) but when I press the button on the remote nothing happens. Popped the cover off the remote and it does have a red LED in it thats lighting up when I press buttons.
