Defiant
DSM Wiseman
- 34,745
- 228
- Jan 13, 2003
glorious Galt,
California
RF. I'm surprised anyone would make an infra-red remote for a car alarm. Although by now, I shouldn't be.kyledykstra said:Are the factory alarms IR or RF??
jaxon23 said:lay down under the drivers dash (head by your brake pedal) and look up and you will see it close to the side wall of the middle console
-my e-mail: [email protected] Thanks..
So EASY..and Iam finding it for One week!!!
jaxon23 said:yes the diagnosis connector. ahoi yoksumash
boosted95 said:ummm...I don't think the color should really matter. Are your doors closed? Just double check and make sure you have the right connector. I'm pretty sure you do. Maybe try a different kind of wire??
tbehling, PM defiant...he knows alot about that stuff.
MarsaGSX said:Hello guys, Got same problem on my Eclipse as dsm4life..I make jumper wire betw. 1and4 pins,close doors,turn key to ACC then back to LOCK, and power lock buttons don´t work...??why (they have to lock/unlock-it is a signal that alarm ECU is ready to be reprogrammed???
I don´t have door switch on CO-driver side..Can be there problem?
Next ..Work this system without keyless remote(in car black box-near rear speaker on driver´s side)
I think my remote is "bad" Is "rusty"-not so bad,but...
Let me know please
Defiant said:
http://www.dsmtuners.com/forums/showthread.php?t=145182joboyz96gst said:Has anyone been successful at reprogramming aset of remotes for keyless entry.
Thanks for the advice and rep points for both of you
streetlegends said:Does anyone know how to program a keyless entry remote? It's for a sypder or should I just pay the 36 dollars for the dealer to do it? The remote itself is 95 bucks plus the cost to program it.
All bets are off. I'd look for another aftermarket system and start from scratch. Sorry.RedTurboEclipse said:There was an aftermarket alarm that the previous owner put.
