Wun-jee Claud
- 26
- Dec 30, 2021
Burton,
Michigan
Thanks for the reply and yes.. I do like larger wheels... "Cheap way" for me to squeeze out some more top end... And the tires are cheaper-ish
I end up taking things apart and rebuilding at least 3 times regardless of however many notes i leave.. Apparently, the notes i leave are just for show and nothing more.Oh, and my big cardboard note to self to tighten the water pump pulley nuts before putting the motor mount back in and buttoning up was useless.
. Didn’t get the greatest of pictures.Looks great.Thanks for the pictures, and also blown away no 1G DSM's at MOD!!
Sprayed a couple quarts of POR15 top coat yesterday through my $22 HF tools HVLP gun.
Where was this at?Went to MOD in New Jersey on Saturday.
First time I have seen so many Mitsubishi in one spot. Didn’t get the greatest of pictures.
No 1ga’s or 1gb’s their and no vr4 galants
I daily my DSM and pretty much every ACT disk I've had has done that. One time the PP started falling apart but the result was the same. So I switched over to a Southbend.So couple weeks ago, I sat at a light waiting for green light, let go of the clutch and floored it through 3rd and started coasting to the next stop sign. Went to down shift and realized I couldn't get car back into gear. Pedal felt fine, after few pumps got car into first and flat shifted it home.
Check the reservoir and fluid was black, so proceeded to flush and bleed out. Car went into gear fine again but only for few mins then car would again not let me into gear. Bled clutch couple times and every time I would be able to shift through gears while car was on for few mins then it would stop. Always was able to shift car with engine off, problem only happened with car running.
Replaced aftermarket slave with OEM unit, same problem, tried CMC same problem. Finally yanked the trans out and discovered the issue.
2 cracks in disc, broke ear off the spring, and it wedged itself in the pressure plate. Also hot spotted the ACT flywheel which assuming I did messing with hydraulics. Nothing like a 8k chromoly needing resurfacing
So new act 2600, resurfacing of flywheel with proper step, and now it can go back together.
Least should be ready to break in another clutch by tmrw night.
Liccardi Mitsubishi in green book township nj.Where was this at?
I've had the same happen to a Southbend, so it's definitely not unique to ACT.I daily my DSM and pretty much every ACT disk I've had has done that. One time the PP started falling apart but the result was the same. So I switched over to a Southbend.
I've had multiple ACT clutches over the past 2 decades and not had this kind of failure. I've seen the ears break off clutch springs before, but never the disc itself. Nor am I putting down the kind of power that I would expect tooI've had the same happen to a Southbend, so it's definitely not unique to ACT.
Hopefully just a tooth and no damage! Been there myself. Good luck!34 years of this and you can still get bit. My 95 jumped time today. It was leaking oil, I knew it. I have nobody to blame.
What was the source of the oil leak ?34 years of this and you can still get bit. My 95 jumped time today. It was leaking oil, I knew it. I have nobody to blame.
Unlikely. Main belt isn't moving so it probably shredded teeth.Hopefully just a tooth and no damage! Been there myself. Good luck!
Front balance belt seal. I think I ni ked it last time i was in there. I flat out kept putting it off and it bit me. Sooo, here comes a fresh cylinder head.What was the source of the oil leak ?
