What did you do to your DSM today?
Thanks brother, It just has the Megan mid pipe. Its a resonator.
That dash trim is awesome! Did you create that file and print it?
I have some wiring planned for the winter. Basically remove wires from the engine bay that are no longer needed, consolidate branches, and get rid of all the wiring under the radiator. I want to branch them cleaner. My bay has a birdnest on the passenger side and is such an eye sore
Not at all I find it on eBay there's a company that makes them
They also have the 3 pods as well
Had to bench test the glow shift harness to make sure the sensor ran on a 5v reference. Made a new connector at EGR wiring, wired fuel pressure into the ecu. need to set parameters tonight and take it out for a rip.
3 Pod would be sweet! I think I want to tray and build oil, coolant into my factory dash first now. I have seen a couple on tuners and a buddy of mine has his done that way
That's the 3 pods trim
Filled up my Transmission!
The Schaeffer’s arrived with a quart of Red Heavyweight Shockproof as well for the Transfercase :)
Beautiful work
Little bit of an update...little bit of a vent. Im working on trying to figure out/troubleshoot why my A/C fan won't kick on and why the A/C compressor isnt engaging still. I suspect its either the ACCU, thermo sensor, pressure sensor or the Ohm harness (which is unfortunately at the high end of the list due to my previous issues with it).
Is OHM Racing a one or two person business? If so then I can partially excuse their bad customer service, more like lack thereof, but geez man they KILL me with it sometimes. Especially when I try to reach out across multiple platforms to try anything that works best for them and nothing. No follow up, no re-directing, nothing. Just a seen message left high and dry. And this has been from start to current with them. Ever since I even inquired about the harness. And if they ever check around through the community it seems that their reputation for bad customer service, not responding, and being hard to reach is pretty well established.
Sorry for the long rant but I need some reasoning on this seemingly unwarranted frustration. For the money they have people spend and the products they offer, I just expect more and thats not just more from the customer service stand point but knowledge on the harnesses they are re-creating and custom building because I've asked questions of them that they couldn't answer and that will make anyone nervous because then you question what else they may not know about a harness beyond its wiring diagram
Man that sucks. I have been thinking about using them, but I almost rather learn through it an build my own
Don't get me wrong, OHM quality is pretty darn good its just in my case I had some issues with the harness itself that I just can't overlook. Take my gripes and complaints with a grain of salt, I'm not out here to tarnish names but I just needed to vent a bit that's all.
But at the end of the day, and like I'll always say, this community gets me through my problems and is a huge reason why I love owning the car. The DSM community is something special and i'll always be grateful for the people because it got me through tearing this car apart, putting it together and getting it back on the road.
That's one way to keep the engine from rocking when the mounts get mushy.
I have solid steel bushings all the way round from Boosted Fabrication, the tubular subframe and aluminum subframe bushings. Poly in the control arms, coilovers front strut bar and a Few other goodies... I call him Woogie...
Here is 20 minutes of marinating the carpet in water and cleaner. Foul. I'll keep going until the water is clean in the kiddie pool.
"improved" the front end links from normal to stupid. Yee :]
Random question what do you think of the "brushed steel" look ?
Has anyone replaced these foam filters before?
I have. I did a complete restoration of all the HVAC boxes behind the dash. They're not really filters, just foam that seals up the doors. I assume yours have turned to dust like mine had? I don't have a write up on it but I took a bunch of photos and I can tell you how I did it.
I guess it should not be difficult to get a replacement foam filter maybe not Mitsubishi OEM but something similar like maybe Lowe's or home Depot and just cut it
  • Wanted Fp header
    Good afternoon, everyone! I’m looking for an FP exhaust manifold/header for my 2G GSX. If anyone...
    • Bebo____pr25
    • Syclone#334
