2G Throttle Body Sticking
kyler021
210
165
Aug 29, 2023
Pasadena, Maryland
Hey all,
I recently rebuilt my throttle body with new shaft seals and a FIAV delete, and now my throttle plate seems to stick. Seems simple, but the weird thing is it only sticks when the engine is turned on. I can't get the throttle plate to stick when the car is off. It doesn't even feel hard to open/close. I'll get some resistance when the car is on around 5-10% throttle but it pushes past nicely after that. Another thing I noticed is that when I turn the car off while the throttle is sticking, I'll go to the engine bay to pull it back to it's resting position and it's already there. (I know this isn't a vacuum leak or anything of the sort because DSMlink will display the throttle position when I turn the engine off and it's greater than 0%.)
TPS and IAC were working normally prior to teardown. Throttle body blade is at the correct orientation, no gouges on throttle body surface.
Things I've tried:
Loosening throttle cable
Lubricating shaft seals and shaft with silicone dielectric grease
Throttle body shaft was wet sanded to remove the gray debris that was on it
Boost leak test at the throttle body showed no visible leaks
Is it possible that I tightened the nuts on the shaft too tight? I couldn't find torque specs anywhere so I just counted the threads on the pictures I had and set it to there. I'm not even sure what else to look for... Something around the FIAV maybe? Help me out guys!
Thanks!
Kyle
So it wants to stick closed? If so, is your throttle stop set to low?
Wow it would've been helpful if I included that in the original post haha, but when it sticks it'll stick slightly open. So it'll rev up to like 2000-2500 and stay there.
I am looking at videos and pictures again, and it looks like everyone puts the flush with the side of the ring thing that the seal pushes into. Would it be bad if they're recessed into the seat? Could that be putting too much pressure on the throttle body shaft causing it to catch and stick open?
Another possibility is that I never messed with the throttle stop... could that also be an issue?
Kyle
Kyle
Not sure on if you can overtighten those.
I do have the experience of having my stop set wrong and sticking closed as well as being hard to start open.
Did you mark your springs before you took it apart? I doubt this would cause anything, just wondering
What you have is the shaft nuts too tight and not central either. Once the casting warms up it expands a bit and jams. I have had this before and was 1/4 nut turn too tight LOL small amount bit jams it.
Can check that and it is central with a light behind the TB to view it.
The lther thing is jamming when closed means the throttle stop is to far back. If you release it slamming shut and it jams its to fsr out and needs to just be allowed open but following the oem soecs is a good first step on that tiny screw
Needed a Pro in here to shed some light! :D
Hopefully, you can resolve this, but doing it on the car can be done but might not be as precise. Ideally off the car is more ideal. Then you can clearly see the gap surrounding the plate. You will be fine and the small amount of widdle in the bar means it is working ok.
Snapping back and not jamming is the check I always do when I rebuild them so make sure to add this check at the end.
It might just be the way I reassemble my throttles after a rebuild, but I had that same problem a couple of times and it drove me nuts. There's other possible reasons that can happen, but what worked for me was to loosen the two throttle plate screws a hair, then clap the throttle a few times, tighten one screw then clap it again a couple times and tighten the other screw. The tiny bit of play thats in the shaft screws is enough to clock the throttle plate enough that it's not seated right, but you won't notice until it gets hot.
So basically, I just need to take the TB off, undo the 2 screws holding the throttle blade on and center it? How do you know when it's just right? When there's minimal light coming through on the sides of the housing?
I don't think this is the problem with mine. It slams shut and it's pretty easy to get back open... Doesn't jam up or give me much resistance.
See that's the thing... Even with the car running, it'll slam shut perfectly fine and open just fine, it'll just occasionally get stuck when I rev it or give it any gas trying to drive it.
Thanks all for the replies!
  • For sale 2g 2G OEM Passenger Door Handle
    2G OEM Passenger Door Handle $25 + shipping and paypal fees* the seal and two mounting bolts...
  • For sale 2g 2G OEM Interior Silencer Pads
    2G OEM Silencer Pads $20 + shipping and paypal fees* these go behind the plastics to the left...
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
