Throttle body flanges
MasterMatt209
475
30
Jan 17, 2015
Danville, Indiana
Just picked up a 95 Talon TSI and the dude who owned it did an egr vavlve bypass and showed me how he did it. I want to unbypass this because it causes a check engine light can anyone help me out? I see three flanges he plugged in top of the throttle body labeled P, E, and A where do I need to hook them up to and where should I get the hose to do it?
You see 3 plugs?
Guess what we see........
The answers nothing.
So how can we help?
Coming from the egr valve I figured they all had it. I’ll take a picture here in a few minutes sorry
See there are three tubes there?
My car is a 95 Talon. I attached a picture of what he did, there’s three flanges on top of the throttle body that he blocked off. I’m not sure what benefit that gives should I leave it or fix it?
I linked, and now uploaded, your answer. you may want to pop the hood and look really hard at your engine
The throttle body is in this diagram
Okay thank you to both of you, why would this bypass be done anyways?
A few reasons off the top of my head:
  • Failed emissions component(s)
  • Reduced chances for vacuum leaks
  • Visual aesthetics
  • Visual aesthetics
Okay thank you, it has a check engine light and he said it was due to having bypassed the egr valve. So is there anyway to get rid of the check engine? Or is the only way to fix it to put the stuff back
Assuming everything is in working order, you would need to hook it all back up. ECMLink is another solution, albeit, not the cheapest of the two.
Okay thanks for the info it’s 1 degree outside and I’m about to do some work on it haha
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
