3D Parts Files
THIS THREAD IS MEANT TO BE FOR PART FILES TO BE ADDED, NOT TUTORIALS OR A GUIDE !
Discussion/Request Thread https://www.dsmtuners.com/threads/3d-parts-discussion-requests.548798/
In order to help the community, I thought it would be a great idea to have a main thread with all 3D print parts.
You need to specify the model, make of the car and some photos of the part (It would be great if you will post a photo with how the 3d printed part fits on the car).
It would be good if everyone who works in the field and models and prints 3D parts, post them here, so that we can give everyone the opportunity to complete their cars!
i tried to do the rear cover for bearings in the knuckle
Hey guys, this weekend, I’ve been working on a 3D model for a window switch/door trim piece for a 2g coupe. I'm using my Bambu P1S printer with ASA for the print. I started with the passenger side since I already had that door panel removed from my car and was working on the door handle.
I wanted to share my progress here. I’ll post an update soon with the final files for both the driver's side and passenger side. Below, I’ve attached some renders of what the model should look like, and I currently have my first full prototype printing.
To make it more accessible and printable for everyone, I’ve broken the model into two pieces due to its size. I’m using an interlock system to connect the two halves, which I’ve had great success with in the past. Although I'm not finished with the files yet, they will be available for free download once they’re done.
In the future, I also plan to create my own version of shifter bushings intended to be printed with either 90A or 95A TPU, but I might not start that until next year. If you have any questions or updates, feel free to private message me. I try to check in and catch up a couple of times a week. Thank you all for your support to this community.
Did you post this STL somewhere?
I am not sure but i modeled for 60 mm i will print on my own 3d printer i will share the results.
Here’s my go at the 1G double din radio trim piece.
Thanks, sir. By the way, do you have this 3D part shown in the attached picture?”
Anyone happen to have a file for the automatic shifter surround? was taking my center console out and the surround just disintegrated. The only part # I can find on it is MB910568…but that doesn’t come up anywhere that I can find. Was hoping someone had a scan of it?
1G FWD Clutch Release Cylinder
All shown parts should be in the .zip file.
I just want to say you guys are kicking ass on posting 3d models. I'm definitely interested in trying some out.
"Hard" shifter base bushings for a 1990 shifter. These will probably work on other models. Print 8 of them and install to really lock that shifter base into the car!!! I didn't torque these down crazy hard, you may want to print as solid.
STL included below.
you could print these out of TPU to retain some amount of stiffness without being completely rigid.
Here's my attempt at the retaining tab inside of the door cards of a 1Gb (this is the "tall" one nearest to the speaker, the rest of them are shorter so the model would have to be modified for those)
Replacement insert for the "coin holder" on a 1Gb. It is designed to fit a bass adjustment knob for a Recoil RED1800.5 amp, as well as this panel mount USB 3.0 port from Amazon which I ran to the head unit for Android Auto but I could maybe see it being useful to hook up to ECMLink too or just phone charging maybe?
The USB port didn't fit perfect, still was a little wobbly so I had to glue it in, so this could use some tweaking.
MB522107 - 1G Ash Tray Assembly
The .zip file is of the assembly which should have all (9) individual components included.
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale 4G63 FIC 1200cc Injectors
    FIC 1200cc Injectors $350 + shipping and paypal fees* injectors were cleaned 6/23/26You must...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
