2G 2g DSM 95-96 97-99 wiring schematics, ECU pinouts, diagrams, TCU diagrams, ECT.
I started a thread on an electrical issue i was having. And came across lots of 2g 95-96, 97-99 wiring information. But it was across many threads and websites. so i would like to put it all in one place for everybody!
This is what i have so far!!!
I would like this thread to contain as much electrical as possible for the 2g dsm both 95-96, 97-99 eclipse gst, gsx
please add any and all wiring information or labeled diagrams/pictures you can to this post.
if you have a better quality image then someone else please add to the thread. Thanks!
-how to post:
year of 2g (ex. 95-96, 97-99)
short description of what your posting
automatic/manual transmission (if known)
95-96 2g factory electrical service manual
97-99 2g turbo factory electrical service manual
95-96 turbo ecu pin out (click to enlarge)
95-96 2g turbo ecu pinout with voltage/ground specifications (click to enlarge)
96-99 2g turbo OBD 2 Pinout information
Pin 1 Yellow to ECU pin 56 (Diagnostic Mode)
Pin 4 Black to Ground #5
Pin 5 Black/White to Ground #5
Pin 7 Pink to ECU pin 62 (Diagnostic K-Line)
Pin 14 Yellow/White to ECU pin 86 (Vehicle Speed Sensor)
Pin 16 Red/Black to ECU pin 80 (Backup +12v Power)
95-96 2g turbo wiring schematic (simplified) alldata (click to enlarge)
95-96 2g anti theft, (simplified) alldata (click to enlarge)
how to make an engine harness, video is of a 1g dsm (youtube)
97-99 2g turbo, engine bay electrical connectors, (dsmtuners)
https://www.dsmtuners.com/threads/2g-engine-bay-electrical-connections.298047/
95-96 2g FWD TCU (Auto transmission) wiring diagram
95-96 2g AWD TCU (Auto transmission) wiring diagram
97-99 2g FWD TCU (Auto transmission) wiring diagram
97-99 2g AWD TCU (Auto transmission) wiring diagram
update... i got a hold of a better schematic for the 99 dsm. check these out. huge thanks @Jk's97DSM
2g 99 wiring schematic (click to enlarge) very easy to read when printed
No problem. The factory diagrams aren’t forgiving on the eyes when you look at them but the updated ones from certain programs make them a hell of a lot easier to read and understandz
did a bunch of custom wiring. heres a diagram of the blinker box and hazard switch
2g dsm 97-99 blinker box and hazard switch wiring
Hi, I'm new to all of this! I was wondering if this also works for an Eagle Talon Tsi 1997 or would I have to do some searching around the forum?
i though i should point out that the
in the first post is for the euro spec eclipse which has the non-turbo 4g63. The wiring is not quite the same as north american turbo 4g63 vehicles.
i may have some stuff your missing.
if you wanna take a look the link is
http://www.mediafire.com/folder/5k14qlaulb9s1/DSM_MITSUBISHI
Does anyone have the 95-96 2g GS (420a) Factory electrical service manual? I've searched for it with no luck.
