DSM TPS wiring explained
There have been many threads asking for the specifics. Hopefully putting the information in one place will make it easier to find.
For future reference from the FSM: (which everyone here should have)
1G 4G63 TPS
1 - Green/Red (+5v Sensor Power) ECU pin 23
2 - Green/White (TPS output voltage) ECU pin 19
3 - NC
4 - Green/Black (Sensor Ground) ECU pin 24
2G 4G63 TPS
1 - Green/Yellow (+5v Sensor Power) ECU pin 81
2 - Brown/Red (TPS output voltage) ECU pin 84
3 - Yellow/Red (IPS switch) ECU pin 87
4 - Black (Sensor Ground) ECU pin 92
1990 TPS are different, both in format and in their wiring.
Like the 2G TPS, the 90 TPS connector includes the TPS power, ground, and output, plus the IPS signal. Unlike the 1G and 2G TPS the wiring connector is via a pigtail to the engine harness and you can't replace the TPS without also changing the pigtail. You can't swap to a later TPS without changing the wiring, throttle body, and fuel rail due to these differences.
1990 4G63 TPS (Engine harness wire colors)
1 - Green (IPS switch)
2 - Green/Black (Ground)
3 - Green/Red (+5v Sensor Power)
4 - Green/White (TPS output voltage)
Pins looking at the engine harness connector the pigtail plugs into.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
