sakroda
- 233
- 36
- May 3, 2016
İstanbul,
Europe
Hello there
I have a Zeitronix ZT-2 wideband. I have the gauge and one ECU unit. As far as I understand, Zeitronix made two different versions: one that works with the LSU 4.2 sensor and another that works with the LSU 4.9 sensor.The one I have works with the LSU 4.2 version.
What I want to do is see the AFR data in ECMLink, but no matter what I tried, I couldn’t get it to work. Either this version is not supported, or I couldn’t manage to configure it correctly. I would be very happy if you could help me with this issue.
By the way mine harness is for 4.9 but ecu is not matching with 4.9.
According to ECMTuning ZT-2 pin 2 goes to ECU pin 15 (EGR) and ZT-2 pin 8 goes to ECU pin 24 (sensor ground) with/without sensor ground did not work out I want you to know it.
