2G Zeitronix ZT-2 & ECMLink - Flex Sensor
SwiftKidGSX
100
8
Jul 11, 2003
Cerritos, California
I have a Zeitronix with the LCD display, pre 2010 model. http://www.zeitronix.com/Products/LCD/LCD.shtml
Wondering if I can tap into the flex fuel signal going to the ECU from the MAF plug out in the engine bay into the the Zeitronix to display E85 percentage using the ECMLink setup?
Below is the input info for the Zeitronix. http://www.zeitronix.com/Products/zt2/zt2.shtml
  • User1 Input: Blue Wire
    - 0-5 volt analog input. Voltage data is viewable on all models of the LCD display.
    Software support for the display of Zeitronix pressure sensors.
    - Customized data conversions can be entered to match 0-5 volt sensor specifications.
    All converted User1 data values are displayed only in the software.
Also, if this was doable, what ECU pin would I tap into from the ECU Pin Out?
http://www.dsmlink.com/images/forums/2GECUPinout.pdf
Thanks guys!
