Your most recent welding pics
150 is slot of amps LOL I'd prob been at 120
Ah you have much to learn little one. It's different when you use pulse. Also I probably should have used a little more amperage but I will on the next.
Where can I buy a sight glass? And who has the best pricing on a prowerks cap?
No the hose itself.
Big thanks to ebailey95 for the dimensions. That is a fun project. I haven't put the top piece on yet and have to figure out a cap first. The long side with the bends was a bi***. I cut out a piece and scribed them with my angle grinder and bend by hand over the end of the work bench. Came out pretty good, I have to trim about 1/8" off the top though. .100 5000 series aluminum sucks to bend by hand LOL. Glad it wasn't a 6000 series or I would still be trying.
I didn't bend the long section on mine, I cut three separate pieces and welded the seams. Looks great man. Glad someone else could use the design!
Got about 1.5 hours of cutting/welding time today.
Finished welding that can.
Cut some dice out of 1/8"
Cut 2 spark plug covers. One out of .100 aluminum and one out of .72 stainless. The stainless is bi*** to debur.
And enough pieces for 2 more of the overflow tanks if anyone wants a diy project
Did these the other day for someone
It pressure tested to 67 PSI before our pump failed LOL I'm confident in saying its water tight.
Its good it dont leak now. But it might develop over time though. Ive seen tanks fail after a year and its a minor leak but just saying for next time bring them closer together and not only will it be slight better it will look alot better aswell. And get them edges too and have a smooth corner
No way if he sands those edges it will be weak. The strength of aluminum welds are in the beads themselves. So sand it and it doesn't leak but it will be really brittle and leak really soon. I bet you his holds up fine for years.
More filler doesn't mean more strength. Also maybe the ones you saw were welding with 5356? It's more prone to cracking.
Have you ever heard of autogenous welding? Means welding without filler. And it is still water tight
Granted it's not as strong as filler but were talking about an over flow tank that will see no pressure
Which would mean the tank can't really be pressurized if there is a drip hose ;)
I mean i guess it is oressureized but nothing aluminum couldnt take.
The only "pressure" there will ever be in an overflow tank of this design is the weight of the coolant inside of it. The drain tube drips only because the coolant is being displaced by trapped air in the system, or more coolant. AND even if the coolant reservoir WERE to be sealed and pressurized, you're telling me the aluminum tank is going to burst before any of the hoses?
I'm not, the ither guy is ecl17pse
Enough overflow tank talk...... here's some more weldporn. According to me because that weld porn guy from Australia dosent think so. What do u guys think it's this "weldporn" worthy??
Here's a bunch from an ecotec header i built yesterday .....
mike
Fuqqqqqqqqqqqqqqqqqq i need to train under you how are your stops and starts so damn good, and can i see your purge setup? I keep having spit back issues :(
Do you go continuos inch by inch or do you switch to 6 o clock after the first inch then back to 1 o clock then 7 etc?
How much cooldown time between stops and starts?? Still 66amp?
How do you like the 221 mike ?
The weldporn guy is an asshole and his gloves SUCK. Don't bother with them.
My normal helmet flickers pretty bad when on low amperage dc. So I had to use this ole raggity hunk of crap, I mean the lens is duct taped on. Really thing walled SS down pipe I had to add a flex pipe to.
As always, AMM shows us how it's done, drops the mic, and walks away. Yes sir, THAT is weld porn. :)
I haven't contributed to this thread in a while. Here's some pics from one of the last subframes that we finished.
Woot woot. New torch setup. #9 torch and #12 cup. Also have a number 10 cup. Now to find some stainless to play with.
