Your most recent welding pics
How do you even measure for a sub frame job like that?
Carefully. :) I have 5 times the amount of time into fitting tube than welding tube. Fitting is definitely the more complicated part of it. But the more I do, the easier it gets.
Does chromoly rust?
It will surface rust. Not too bad though unless it's in direct exposure to moisture or somewhere incredibly humid.
Or are those HAZ marks
I'm not sure which marks you're refering to. HAZ shows a little more when the surface is DA'd (mill scale removal). Some of the heat marks in the pics above is from the tempering done after welding. Chromoly turns a dull gray after tempering.
I didn't know if it was rust or haz marks cause i didn't know if you wire wheel'd anything or how old it was. Nothin inportant
Awesome subframe paul, tons of engineering in there
my weld on sch 10 .. still learning, nothing like AMM, compression or paul
Psh LOL what about me ;)
I guess i font post enough.
Oh and urbans welds ;)
How's that header coming along, Warren?
I'll be starting my next compound build in a couple months (weather permitting). I only have the patience to work with sch-10 about twice a year, but that always keeps be looking forward to the next build. :)
The header is coming along slowly, but I am enjoying the process. I got a little side tracked on the car, basically redoing some of the exhaust so that it exits the reverse lights :)
beyond that nothing to crazy, I really look forward to watching your new manifold build, It will be beyond epic as is all the stuff that you do. :thumb:
Okay spill it, which set of turbos now?
A 20g and an HX52. The 20g is in a large, reworked T3 housing with a 60mm gate. And the Holset will be stuffed into a large Tial v-band housing with a 45mm gate.
Both turbos were already rebuilt by Justin. I just have to square away the v-band housing for the Holset and they'll both be ready to run.
Did a mig vertical corner joint, here is a cover pass and the penetration
Also, an overhead bend test penetration and cover pass
My latest welding project. Can anyone guess what it is? Clues: It has a threaded boss on the underside at each corner, and the 4-hole pattern on the one corner might give it away.
