ECMlink WOT pull how is SD chart
I get -46.9 for 880's at 43 psi and a stoich value of 14.08.... which is exactly what your log is set to. So, I would just leave it.
I was reading that my PTE 880s flow some were around 830/840, So with your calculation i should set them for 880cc in the fuel tab and not what i was reading?
Forget what you read; Tom tested yours...remember? :)
Keep your global where it is, use Tom's DT values, and work on getting CombinedFT closer to 0 at idle and cruising (closed loop) using just VE table adjustments.
Work on that ^ for a while (it takes a few runs with the Combined FT SD adjust tool), and then post up a log... and we can go from there.
