sd chart question????
95tsiawd0330
124
Feb 9, 2012
woodlyn, Pennsylvania
OK i need some advice i am going to start doing 3rd gear pulls and would like to know what would be appropriate numbers on the bottem of the sd chart.If my cells are at 110 is that to high of a number?should they be no higher than 102 on 30psi?what is a stopping point to say that is to high of a number?
WAY to little info, And regardless there are a lot of ways to tune a car depending on how it's initially setup those numbers may or may not be what you need to be at to hit your target AFR. No matter what you will just end up having to build your VE map for your motor and setup as no two cars are exactly the same.
Basically there is no real answer to this question as it really vague question to begain with an unless everything is in good order and you post some kind of log for advice along with your setup. Nobody is going to be able to say too much with out that. Even then you still have to just tune the car to get it to do what you want in the end.
