ECMlink sd ve adjust (combindft) question
95tsiawd0330
124
Feb 9, 2012
woodlyn, Pennsylvania
Ok so i read (How To Tune a 1G V3 SD ECMLink with no MAF) and i did the step by step that Aaron Ruppert AKA Dr Turbo tells you to do.so i got to step 8 Non WOT SD Tuning and went on a 30 minute cruise log and when i finshed the log i right clicked the values area in the bottom of the data log and select the SDVE Adjust (combindft) and a message poped up saying "note 1 this function can ONLY suggest updates to the ve tables in areas (BOOST AND RPM)where data is provided in the log files.This can leave others grossly out of tune.You will need to adjust these other areas yourself or collect more operational data for those areas".so my question is when i am doing a cruise log is it ok to go in to boost and go to higher rpms so it can collect data for my sd tables when iam in boost. :confused:
All it's telling you is that it can't make suggestions for areas of the map you didn't enter during the time you were logging. It's nothing out of the ordinary. As far as getting into boost though, I wouldn't do it until I had my idle and part throttle/cruise worked out pretty good. From DSMLink's standpoint though, yeah - it's fine.
