1G wont start
tsimiz
167
Dec 18, 2002
STAMFORD, Connecticut
i have a 1g automatic awd talon, i pulled the car in the garage last night and now it wont start.
I change the starter and it still wont crank. I tested the wires and they all work.
any ides?
did you check you battery connections? are they clean and tight? When you try starting your car turn on your head lights and try to turn it over if they dim when your trying to start it than the battery is your problem. if that is the case make sure you have your alternator checked to make sure thats not the underlaying problem
No bad connect here battery and connnect is fine
I tested the starter and it gets the signal when I turn the key.
It just won't turn the car over. Sounds like it is stuck or something
does the starter make a clunk nose when engaged? or any noises at all? I know you said you have checked the wires but you may want to double check your ground. it really is starting to sound like a ground cable issue. you can always try hooking a set of jumper cables to you ground post of you battery and connect the other end to your block. try that. that will at least eliminate your ground wire.... if that dose not work have you tried to turn your crank manually?
the click is coming from the starter. I ran a jumper wire to the starter signal and it makes the same click.
it just seems like the started is just not turning over the motor
