Won't boost past 15psi
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
Problem is car won't boost past 15psi no matter what. Profile is up to date. 6262 turbo is about 3000 miles old. Before I recently got a new motor the turbo wouldn't boost past 20 and now not past 15. Got new buschur motor about 2 months ago. Checked tial 44mm springs are good, diaphragm is good, Hallman pro boost controller turned up all the way with heavy spring, boost leak tested and only 1 small leak that I cannot get rid of is on the top of my greddy type r bov where the adjustment screw is. Def not enough of a leak to cause a problem like this. At least I don't think so. If anyone has any other ideas what the problem could be let me know. Thanks
My downpipe wouldn't let me boost past 12. You think your exhaust is restrictive in any way
Yes, 1.1 bar is about 15psi which is what I am maxing out at. Which would lead me to believe that my problem is the boost controller. I just replaced the spring in the boost controller and everything looks normal. I don't see anything that would cause the controller to be the problem. I will try another one out when I can borrow one from my buddy.
how did my megan racing downpipe stop me at 12 psi when I put my punishment racing downpipe let me boost to 20+.
Just a ball park guess. I'm not too familiar with the 6262 turbo, but I'd assume you have the Flapper on the hot side sealed/welded shut, correct? I recently went through this problem on my turbo and the culprit was my door being wide open. Was really hard to build any boost.
I have a 6262 with a t4 hosuing. It uses an external wastegate, no flapper.
Update: Did another BLT tonight and found it still would not hold any kind of pressure no matter what. Fixed the small leak on the top of the BOV, found another leak on where I teed my boost gauge and found a huge leak on the vacuum line going to the boost gauge where it actually connected to the gauge. Odd place for a leak if you ask me. The line was almost all the way off. Fixed that and redid almost every coupler I have with new clamps and making sure they are as tight as possible. Didn't take it for a drive yet but I will post back when I do and hopefully my problem will be solved.
Im currently having this issue on the t 25.. i unhooked the wastegate and capped off the boost source and at wot it wont go past 15psi. No boost leaks at at all.
Could it already be stuck partially open?
Question. If the waste gate has a 15 psi spring in it won't it be forced open at 15psi no matter what?
Check the lines to your MBC for debris.
I noticed one day I was running waste gate pressure only, checked my lines and found some debris which was making the MBC useless, allowing the ball to not seat correctly.
A more restrictive exhaust will actually build more back pressure, choking the engine up, and allowing boost pressure to build. If your 'goal' is to run 20 psi, you should be able to no matter what exhaust is on it. It does effect mass airflow though. I ran my s16g at 20#, then 25#, and could get no more then 28#s/min, on a stock exhaust.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
