Can't Boost Past 15psi????
krazywhitboy
339
Mar 4, 2004
NorCal, California
First off, here are my mods.
Evo3b16g
550's
190lph
Safc
o2 dump
K&n filter
hard intake pipe
1g bov
bleeder valve type MBC
DataLogger (pocketlogger)
My car has been down for 2 months due to a blown turbo. I finally got it up and running with evo3b16g and supporting mods for it. My MBC is a homemade type (bleeder valve) that opens to add boost, closes to subtract. For some reason, i cannot boost past 15psi?? With the mbc closed, i hit 9psi. then i open it all the way, it only hits 15psi. I checked for boost leaks, and had one at the jpipe. Fixed the leak, still having the same problem. I know the WG on the turbo itself is good....I'm out of ideas....
I also believe that my front o2 sensor is shot. The short trim and long trims on my logger do not change at ALL when i adjust the SAFC, nor do the o2 volts fluctuate. The volts stay at .02, and do NOT change. My short term and long terms (on safc) stay stuck at 12% (short) and 17% (long). I don't know if this could possibly be related in any way to my boost problem?
Any help/ideas/tips would be much appreciated....
Yes, you need a new o2. Or the wires are cut/frayed/####ed.
krazywhitboy said:
ok....any ideas on the boost problem?
You're probably surpassing the maximum amount of air the valve is able to bleed off, get a ball and spring type mbc and you should be fine.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
