Windscreen Wipers not working
ChrisP
Apr 12, 2013
Johannesburg, Africa
Hey Guys
Is there any relation (as far as wiring is concerned) between the wiper switch and the original radio?
I'm asking this because since I fitted a Double Din radio (so I doubt it could be a faulty relay), the Intermittent wiper speed (regardless of the adjustable speed it has been set to at the end of the stalk) and the second speed does not work.
If I switch to the fastest wiper speed, the wipers work but if I had to change from the fastest speed to a slower speed, it stops working. The strange thing is that if I switch it from fastest to medium or slow speed, the wipers stop wherever they are at that moment (e.g. in the middel of the Windscreen), it doesn't return to the resting position. It takes a bit of practise to get it to stop at the bottom :shhh:
It's a 1996 Eclipse GST.
Thanks Guys.
Some additional info: The Oil temperature gauge doesn't work either since I changed the radio.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
