Will these work with an SBR turbo?
soldave
737
Feb 17, 2008
Okinawa, Japan, Asia
Think I'm going to be getting hold of a SBR-G50 or G60 turbo in the nearish future and am currently looking at oil lines to and from the turbo. Now I know SBR has their own kits, but I have noticed this feed line (here) and these return lines (here and here) from Extremepsi.com. Was wondering if these would work with the SBR turbo(I'd make sure I got the Garrett style fittings). Don't see why they shouldn't but just wanted to make sure, as it would save me a bit of money and every little helps!
Thanks in advance :)
Well if your getting the g50 and g60 don't use garret lines. SBR has there on lines on there site so if your gona buy the turbo from them just get the lines as well.
I'm not as I'm going to get the turbo from a friend.
Well to be honest the g50 is a bolt on turbo for the 1g 4g63 and sence you have an evo 1 you should not have any problems using those lines ..
but it should bolt up to your stock lines.
SBR G50's use a Turbonetics CHRA that is identical to a Garrett T3. All Garrett T3 oil supply and return accessories will work.
Stock 1G oil lines WILL NOT work with a G50. By being a "bolt on", they mean it bolts to your stock exhaust manifold- all the other fabrication is up to you.
