Will my transmission fit?
pkgto66
Apr 28, 2005
Chesterfield, Missouri
I have a 1997 eclipse gs and i am going to buy his gsx motor. I know i will need a stronger and better clutch and flywheel. WIll my transmission fit on there or will i need to get a gst transmission. I also wanted to know wat else i have to do to the tranny to make it work>
[email protected]
AIM-pkgto66
[email protected]
AIM-pkgto66
Your transmission will not work. The engines out of GS-T/GSX's are complete different engines than yours - you have a Chrysler 420a, whereas his is a Mitsubishi 4G63.
This engine will not be a straight bolt-in on your car. There will be much work involved in installing it, and you will need to find a donor car to pull the subframe and various other parts from -- everything from ECU and wiring harness to engine mounts.
Unless you are an experienced fabricator and have a large supply of money and time on your hands, I would avoid attempting a project like this.
