will i reach my 650hp goal?
pyanac711
109
Feb 21, 2012
hazle township, Pennsylvania
just looking for some input.
7 bolt built bottom end
JNZtuning new built 7-bolt bottom end. Eagle crank, eagle rods, ross .020 over 8.3:1 Compression pistons, mitsu oil pump, b/s eliminator kit, Every part is new down to the oil pan and bolts.
MLS head gasket
Race head 7-bolt. needs springs/retaines. Head is ported/polished, brand new ss valves. prob go dual titanium springs, titanium retainers, has +1mm o/s intake valves
I am looking to run a hx40pro turbo
still researching injectors
prob run kelford 294/292 cam combo
meth injection
L19 head studs
Shearer Fabrications - Products manifold like that one
tial 44mm wastegate
thats another thing i have to research a lil more. will dsmlink v3 be efficient enough? i have a safc with a flashable ecu but thats going to be sold when this motor goes in.
Get v3 full I prefere gsc s2 or s3 cams. Also not sure about those ross pistons I will research them later I hope they hold up, best bet is the wiseco hd pistons. Also you will need like 1450cc atleast if you plan on running Ethonal. Also You could got away with like a 9:1 compression motor for little more power and I know Ethonal likes it. Also best turbo I have seen latley on the dyno making 700whp is the 3586 turbo from fp. Good luck.:thumb:
Going by your responses and overall thread. you shouldn't be going for more than 400 at all. You're over-doing it.
The new 294 Kelford cams are WAY overkill. I suggest you learn before shooting for a high number such as 650.
What he said. I would go with a less aggressive cam setup with the hx40. Using those cams would be like putting a 42r on it and hoping to hit 400 crank hp :D
I like the hx40 idea though. I didn't have the pro version, rather the restrictive BEP bolt on hx40, and it was a really fun car to drive!
Wade
WOW...all I gotta say is that when you get this project done you should put those pesky V8's in your pipe and smoke em...:thumb:
Haha will do it does now with a stock bottom end running 25lbs on a 50 trim
I'm prob not going to use those cams mybe 272's or 280's which out of them puts down the best numbers down on the dyno?
It has a fully built JohnShep stage 3 race trans with a Quaife LSD, B&M short shifter, symborski shift kit, and brass shifter cable bushings. Kinetic short route intercooler 3 inch piping, Walbro 255 fuel pump, Magnus intake manifold, Dejon intake, custom o2 housing, and exhaust to a Thermal R&D cat back. It has an Aeromotive adjustable fuel pressure regulator, mitsubishi exhaust manifold with external Tial 38 wastegate, Tial 50mm blow off valve, Koyo radiator, Mishimoto cooling fans, Gates racing belts and hoses, Prothane polyurethane motor mounts and all the Prothane polyurethane suspension bushings as well. Tein superstreet coilovers and EDFC controller for them. RM racing swaybars and Megan racing strut bars, Powerslot rotors & Axis metalmaster pads, and installed a H.O 165amp aftermarket alternator I'm going to have stage 5 axles built might of missed some stuff
