Will I make my Goal?
91whiteGSX
101
Jul 23, 2007
Toms River, New Jersey
This is my frist build so Im not sure where im gonna end up... So far I got my 6 bolt Block cleaned honed and BSD yada yada, Polished stock crank , stock main bolts , Recon Rods arp'd ect, New Evo 9 Piston / rings, Oem MLS, ARP hed Bolts, stock head and cams , 560 Inject, AFPR, 255 Pump, FMIC and running a MHI small 16G.. not sure what PSI to run it at .. As far as tunning Wide Band A/F.. Boost.. Link V3 lite... I wanted to see 250 to 300 to the ground .. But Im not sure ??
I would think you are right on with those power goals. You didnt mention exhaust, but a 3 inch exhaust with that set up "should" put you right around that 300 hp number.
As for how much boost to run. Log with Link and see how your looking for fuel. if you start getting close to max out your injectors, your looking at about the most boost your going to want to run. That is assuming there isn't much (if any) knock.
Yeah Im gonna try to do full exhaust but i have to keep it cated casue its jersey and i need it to pass
Put it together and find out for yourself, then report what you found out. No fair and definite answers can be given ... just close assumptions.
Nobody is going to give an answer to put themselves into jepardy if your results doesn't match what was told you. Why sysops and wisemen stay out of this one.
