will a hx35/40 hit the water pipe on a 2.4l???
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
I know the block is slightly higher on the 2.4l engines so i was wondering if someone knows first hand if it will hit the water pipe or clear. Im looking into turbos as i am purchasing very soon and am highly interested in holsets. Any info will help!
considering that a 2.4 will use the same water pump as a 2.0, it would be safe to assume the water pipe will be located the same as well. With a bit taller deck height the turbo will clear even more as they do not require any modification of the water pipe on a 2.0.
If it does hit, it wont be hard to modify it.
I know when I installed the hx-40 with the FP manifold, I just added a spacer instead of denting my coolant pipe.
I never had stock fans while doing the swap.
I assumed my engine would get hotter with more hp I would receive, so I upgraded my radiator and both puller fans at the same time.
Sorry I can't answer that..
Are we to assume that you're talking about the BEP bolt-on Holset turbine housing being used with a stock exhaust manifold?
Obviously, the clearance is going to depend on what position the exhaust manifold you use places the turbine housing your using.
You can find a way to fit pretty much any turbo you want into a DSM if you make your own exhaust manifold, so be specific.
I am running a HX-40 with a BEP bolt on housing on a DNP mani. No clearance issues with the water pipe at all on mine. The stock fans will have to go. 1/2 radiator or 2 slim fans on full size radiator will work.
