Bud92gsx
Welcome Wagon
- 23,178
- 428
- Jan 16, 2008
Wisconsin,
Wisconsin
Reflashing a tcu I have no freaking clue man..
..You can modify the buttons on the steering wheel to shift when you press them..You have to have the roadsurge shift box,, and a 2g steering wheel..
It's in this thread somewhere about using the horn buttons to shift.. http://www.dsmtuners.com/forums/drivetrain-tech/403412-help-tcu.html
To find out if the tcu is an eprom just open it up there should be a chip, in there somewhere..
But sometimes the E on the fron't of the case is misleading..And does not always meen there is an eprom underneath..
Like with my factory ecu I thought it was eprom for a long time before I decided to open it up and find out for sure..And it wasn't..So like I said the E on the case can be misleading..
thats only in a 2g you will have problems.. 1-g's will get great gains. thats IF its only the smaller of the two honeycombs you remove.Wait.
I know you are concerned about the shifting, but removing the honeycombs on our MAF sensors is a bad idea without some way to tune for the change in metered airflow. Does your "tuned ECU" have a chip that compensates for this? If not, don't be surprised if the car runs worse without them.
Oh, and if it runs better, congrats on your 2hp free mod.
Both of my Talons have been AWD autos and both always up shifted at 7000 RPM when at WOT.
If the TPS shows less than WOT while your foot is on the floor it would cause the TCU to shift at a lower RPM. I second the TPS check.
