Which/What gauges should I get? [Merged 12-6]
In my truck, I went with Boost and fuel pressure. If i was going to get a 3rd I would do tranny temp, just cause Ty's have common tranny problems. Or i would go with EGT.
depending on how modified your car is, boost/egt/oil pressure/fuel pressure/water temp ... i wouldn't trust the stock oil/water gauges (and a real A/F meter... though im getting the little blinky flashy LED just cause it's only $40 and im sure it serves SOME sort of purpose when driving and not for tuning)
thanks for your input.
i noticed most of you posted egt gauge, what numbers would a healthy dsm put out, and what would the danger zone be?
I need people to help me decide which gauges I should put in to my car.
Keep in mind my car will be painted a dark "Si" blue, along with a black interior.
So here is what I got and I need some input. I have Greddy Boost and EGT gauges right now...
My mods are basically 20G with supporting mods with safc, injectors and fmic coming soon.
I already have a digital AF gauge (on my TT) so I dont need another light show... :|
I am getting the Autometer Instrument Bezel that will hold 2 52mm gauges. I am definately staying Greddy as all of my gauges are, so keep in mind what they sell :)
A. Oil Pressure
B. Fuel Pressure
C. Oil or Water Temp
If you have any other recommendations for something else then lemme know...
Please explain why you are recommending the gauge that you are, not just cause it looks cool :rolleyes:
Thanks guys, I wanna get them soon, so suggest up!
Brian
well, you will need a fuel pressure gauge when you get an afpr, but that is best if it's in the engine bay. alot of people go with the oil pressure as the 3rd gauge. i have seen people tap a temp gauge right before the throttle body so you know the temp of the air entering your engine. having a temp gauge at the intercooler isn't a bad idea if you have a sprayer.
I already have a boost guage, what else would you guys reccomend me getting? Im not looking to have my car filled with 10 different guages, just what is the most important for a mildy modified car?
Was thinking of adding an A/F gauge and oil pressure gauge to fill up my triple A-pillar pods.
Run an EGT gauge, if you want to start turning up boost this will give you a more accurate idea of how lean you are starting to run when you drive hard.
get an egt gauge for sure, then maybe an oil pressure gauge... the third one really doesn't matter as much as the first two. personally I'd get one that's easy to install, heh, but that's just lazy old me...
I just got one of those a-pillar gauge pods for my car with 3 pods. The first one I know of course I will be putting in a boost gauge, but what should I stick in the other two?
