which turbo should I keep?
Slowboy had the evoIII turbo putting out 44lbs per minute at one point, although I'm sure that those results are'nt typical but it does prove how capable the unit is. It was enough for me to go buy a brand new one from them several years ago, and I'm still very happy with it.
OUCH!
I agree. A good choice in your compressor will put your goal about in the middle of the map. It really is so much better to run a compressor at a lower more efficient rpm. Not so much because of the heat in the intake, but for the midrange increase in VE because not as much exhaust energy is neccesary and can be shunted. And because you may not have the funds to replace turbos every month :) .
Well come on obviously the bigger the better.. I have a big 16g spool time is still to fast. If you want something to continue to pull or pull harder to 5k get something bigger...Im serious
