sbeck
- 171
- 0
- May 15, 2010
Hemet,
California
Current engine mods that I can think of are evo injectors,dsmlink, turbo back exhaust, 255lph pump, 1g bov, air filter, boost gauge, wideband.
I will be installing a 16g and was debating going with some e85 injectors and some piping for the stock sidemount or going with a fmic and making my own piping. Both will cost about the same to do so which would be better first? Has anyone gone e85 with the stock sidemount to see how much it can handle before causing knock? Its only a small 16g so I have heard it maxes out around 23 psi before boost tapers off so that would probably be my limit.
) is common practice and the safe way of doing things without completely destroying your motor. Detonation (knock) occurs from increased CC pressure and temperature, both of which E85 reduces because of its higher octane and lower ignition temperatures that create cooler cylinder temps. Engines that detonate sipping on corn juice don't show one degree of REAL knock in the log, they simply melt. This is often caused by pre-ignition, which is something completely different than knock, or from in increase in EGT's created by the longer burn time of E85 and not enough timing advance.
