Prib9671
- 123
- 6
- Jun 9, 2009
Rathdrum,
Idaho
Just getting around to putting my engine back together finally
, but I noticed that after installing the timing belt it was not centered on the cam gears. I rotated it around several times to see if it would settle or move at all but it's still on the inside edge. You can see that the belt hangs over the cam gear just a hair on the inside. I've done other timing belt jobs before but never noticed it this much, Hopefully it's ok. I assume it is but Please let me know otherwise if anyone knows something I don't.
My question to everyone is: Where does your timing belt ride?
, but I noticed that after installing the timing belt it was not centered on the cam gears. I rotated it around several times to see if it would settle or move at all but it's still on the inside edge. You can see that the belt hangs over the cam gear just a hair on the inside. I've done other timing belt jobs before but never noticed it this much, Hopefully it's ok. I assume it is but Please let me know otherwise if anyone knows something I don't.My question to everyone is: Where does your timing belt ride?
. I guess I will have to just watch it when I first start it up.
