Timing Belt
boostmaniac
54
May 19, 2005
Us of A, Georgia
Is a kevlar timing belt neccesary? Or can I run a stock belt,please I need all the info I need bc this is the last part of my build up and I dont want everything to get damaged from a belt breaking. Thanks
I should have somewhere around 500 to the wheels and I'm not gonna run past 8000rpm
The kevlar belt might be worthwhile if you really think you're going to be driving this car and that engine for more than fifty thousand miles. But even at that, I don't know of a kevlar timing shaft belt, and I doubt the water pump will go 70K.
I've used Gates timing belts for many years and have had no problems. I would however recommend replacing the idlers, the tensioner and for sure, the water pump. Just to cover your butt
Old mitsu tech: where can I get one of those gates timing belts? Thanks for the help guys!
Sorry for the long reply. I tend to get lost navigating posts. O'Reilly auto parts here in the midwest has them. I can't imagine you not being able to access them. Sometimes they are manufactured by Gates under other names. Just ask where you purchase your parts that you prefer a Gates belt. One thing for sure, use the best belt you can get. No cheapies here. Good Luck
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
