where can i get a replacement wastegate actuator female eye bolt?
kleenf4i
259
Oct 30, 2012
tampa, Florida
Some how the c-clip came off the wastegate and as a result ,since the jam nut wastnt tight either (apparently) I lost my female eye bolt that attaches to the male threads going to the actuator and that attaches to the wastegate arm. Does anyone have any idea where i can get one? I cant find anything on this. Thanks
thats not good news. Man this sucks. Id rather switch over to external than to drop 100$ on another one.
because I have a hard time justifying spending 100$ on a part that im ultimatly going to replace anyway. No offense. It just sucks that they dont make and sell a replacement. Maybe IO can find one for about 50$ then for now, like you say, Ill just hold out.
You can get a stock wastegate actuator (not adjustable) for a 14b/16g for cheap off the classifieds. Thats what I meant by my first post. I'd say anymore then $25 to your door would be too much.
ok thanks for the info. much appreciated.
Sounds like you have a knockoff 16G on your car if you're claiming the actuator is adjustable. If that's the case, here's what you need.
Adjusted Rod 70mm L 6mm Hole Turbo Wastegate Actuator | eBay
yeah i didnt know the difference when i bought it. its a borg werner 16g spec. it came with the car when i bought it. Im familiar only with garrett turbos.
I have that eye on an ebay turbo of mine. If i can use a 14b actuator on it ill take it off for you.
im not sure what your saying here. are you saying you would sell me the 14b actuator?
the turbo in it is a borg werner. come to find out through research , its ever so smaller than the 16g but far bigger than the t-28
