need replacement wastegate actuator 14b where to buy one
1990boost
41
Nov 29, 2011
brookfield, Connecticut
need a new wastegate actuator for my 1990 14b, can you recomend a good quality replacement, thanks
I think forced performance sells one that's set at 18psi if you're capable to run that much boost.
I saw that one and will most likely pick that one up, although I'm not set up for 18 psi I guess I could put a manual boost controller on and set it at 11-12 psi and leave it at that.
You can only go as low as the wastegate minimum. So the lowest you could set that one at would be 18psi.
I didn't know that, so would it be safe to run 18 psi on a stock car? I drive it easy so prob won't hit 18 psi anyway.
I personaly wouldn't recommend it. If you don't need it new I'm sure someone has a working one in the classifieds, and if not there, just ask in the regional forum tab someone may have one kicking around from an upgrade.
What supporting mods would I need for the 18 psi wastegate?
I plan on a Walbro pump as my stock pump is orig and I want to replace it, also some 550 cc injectors as well. Don't want to get crazy just a little more get up and go, also will be rebuilding the 14b,
Ok thanks
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
