Whats the correct spark plug
dadnkid
57
May 14, 2011
luke afb, Arizona
Hello all,
Just bought a 99 Spyder GST. Checked the spark plugs and the part number is BKR5EGP, made by NGK. I checked NGK website and they show it for my car but, ran a search on here and it's not mention anywhere. Most are running NGK 6ES for stock. The tip is white which many on the internet say its the wrong size, not correct heat rating, or the car is running Lean. Any help would be great. The car is completely stock. It needs a lot of work but thats for another post...or i can explain here if needed.
People use 6's or 7's...And gap can vary between.24 and .028..I know the manual says.032 but I've never had a problem going with.026....The higher the boost the more you can go down..
So is the BKR5EGP wrong or just another plug. I know everyones prefer the bpr6es but can I use the ones I have? the ngk website is messing me all up. I inserted the link to the website.
NGK.com - Application Search Results
Thank you. Will go get some of the bpr6es. Hopefully this will help
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
