Whats my factory color code.
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
I wanna paint my car the factory color so it can be all original, but I'm not sure what's the factory color code. I have a 95 talon and I know it's a burgandy color. I'm not sure if the sticker tells me on the pic.
its under the hood on the passenger side of the firewall. Most of them fade out but you might be able to see it.
Its most likely PMG / P75, Wildberry Pearl Metallic
So difficult to decrypt the code LOL. I'll try when it gets dark
...or you can call Chrysler or find someone with PIAS (Chrysler parts look-up program similar to CAPS/ASA) and give them your VIN #.
:dsm:
hopefully chrystler still knows abut the eagle talons LOL. so I just call chrystler and ask if they can find out what my factory color code is by giving them my vin?
The VIN number does not include the paint color code.
See the following spec sheet.
1000 AAQ - DSM factory specifications
You will be able to find out what color it is by looking at the code numbers on the paintscratch.com link.
Codes change through the years, but retain the same color as the previous code. You have a pretty unique color. It will be quite easy to figure.
Feel lucky its not one of the 4 different reds :p
Orielly's can make touch up paint, my son just got some for his little nicks and they made it there. I don't know if you have to know someone there or not, but he did use to work there. He has a very small bottle at home, just got it a few weeks ago and it is almost the exact same color as the OP.
The VIN # itself doesn't but the VIN # provided to the dealership can give you any info you need about your car, paint code included...
Download CAPS/ASA and put your VIN # in there if you don't believe me.
:dsm:
I already gave him the paint code, I looked it up through my PPG Paint System at work.
That is what PPG is showing for the car. Its the only color code / color descrption even close to the color of his door jambs.
who in their right mind would do that to a car... :-(
Just an FYI, its NOT easy to remove. Anytime we do a truck bedside, we have to use 40 grit grinders to remove the lining. Aircraft paint stripper may remove yours but it also looks like they painted all your belt moldings, window moldings, etc...
You can only get those quarter glasses with the moldings, they are not available seperate
I was pissed too that the previous owner this. Thank god this was all he did and I bought the car before he ruined everything else. It's not actual rhino line but something like linex. Besides the paint the whole car is all original and unmolested. 83,700 miles.
Good luck with removing that coding before painting the car. Aircraft Paint Stripper might work but its also "illegal" in some counties in California. This would be the easiest thing to do to remove the linex stuff.
If not you will need A LOT of sand paper, LOL
