Resolved What us the thickness of front case / oil pump gasket for 7-bolt 4G63?
Raypiñyoko
May 7, 2023
New York, Central America
Hi what is the thickness of the oil pump gasket?
Is it 1.mm or 0.5mm
This photo i don’t know if what is the thickness they don’t sell here so i need to make my own gasket
Solution
I will throw a digital caliper on one and report back. Thanks for your help Steve!
As promised
I imagine he is asking about the pickup tube (that's a random guess too) and that answer is whatever it takes to seal so the oil doesn't airiate.
A quality gasket of any kind is what I use, Felpro, OEM, Rando, make my own, etc.
They're CHEAP. Buy one at the auto parts store.
See THIS thread.
Marty
See THIS thread.
Marty
Marty, that link isn’t working.
What is the thickness of this gasket?
That would be the gasket for the front cover. Like Marty asked we need to know the specifics of your car. For example there are different parts for 4G63 6 bolt, 7 bolt, 4G64, 4G37 and the 420A engines.
And something tells me you're not really in NYC.
yea im not from NYC im from Philippines my engine is 7bolt 4g63t
And do you know if what is the thickness of this gasket? Pls reply asap
You can edit your posts for a few hours, you don't have to keep making new ones.
1064A040 is the current part number for a 7 bolt 6G63 and while I don't have the gasket based on what I remember from doing a 6 bolt is much closer to 0.5mm than it is to 1mm.
Ok so its 0.5 mm
As promised
Solution
