what size injectors.
96 420a-t
755
3
Dec 8, 2010
Rancho, California
soo after fighting with this setup for soo long I have decided to do away with my fmu setup.
What is a good injector size for a stock 420a running 8psi?
450 would require me to run MS, stock injectors are 190cc but flow around 235cc.
i have a set of 275 laying around i think they might do it with a safc
i will never run over 10 psi so i dont need huge injectors.
You miz well put in the 275's, but honestly you miz well get a set of 450's so thers no reason to upgrade later unless you plan on building your motor..I have a set of 390's laying around if you want them..See what hapens with the 275's and the safc, but keep going bigger in the back of your mind..
450 reqire MS. safc can only handle 400. your 390s will require a resistor box to run
i can log but it is a scan tool i have LOL
everything my computer sees so no, not knock. car doesnt have a knock sensor. but fuel trims etc. yeah. i can record like a logger and i can write them down and transfer themn on here if i really have to.
There you go man try logging and figuring it out with the safc..But if you run into problems, there are plenty of people here on tuners that can help you out with the tune..So please don't blow it up, like I said if you run into problems sumeone will be able to help you out no problem.
I did log and I made a post about it.
Oh. Well that's what that is. But still I can't log knock
