what psi 30lb injectors good for?
White97eclipse
131
Feb 20, 2005
puyallup, Washington
Im about to get my bottom end built so im going to be turning up the boost! :rocks: I cant remember what the equation was for lbs-cc... so what boost level would i be good to go to with the 30lb injectors?
the lbs to cc equation is 10.5 x lbs = cc. as for how many psi can you run? that all depends on the turbo. not all turbo's are going to flow the same amount of air at the same psi, which means different turbos will have different fuel needs for the same psi. you need to do an equations with CFM's in it.
hillbillyboostn said:
30lbs 300cc. i would prob say around 10 12- psi at 80% pressure on the injectors .
no, if you do the equation, they would be 315cc. and im not sure how you just made that psi guess without even know what turbo he's running. he could be running a little RC car turbo with 1/4" piping, running 10-12 psi on that will def. not need 30lbs injectors.
ROFL ROFL ROFL vroom vroom vroom :dsm:
